Is this fuel line routing safe?
http://thorp18.com/thorpforum/viewtopic.php?f=19&t=7235
Author:  Ryan Allen [ Sun Mar 03, 2013 5:45 pm ]
Post subject:  Is this fuel line routing safe?
I now have a fuel pump on my engine and the gascolator is in the same location as before (at about the cross bar on the landing gear). I have attached a photo for reference. The angle from the gascolator to the fuel pump seems excessive. Its about a 51 angle to be exact. Is this safe, normal, etc?
File comment: fuel line from firewall to fuel pump
Author:  Rich Brazell [ Sun Mar 03, 2013 11:15 pm ]
Post subject:  Re: Is this fuel line routing safe?
Hard too tell with the living room barko lounger in the way ! :'( I assume you are going to use SS fuel line vs the "Cheech and Chong" rubber hose ? "I can not sign thee papars as you have broken all my fingers !" :P With the appropriate Aeroquip fittings (multiple angles) you should be able to keep the hose bending/angles to a minimum . ;)
Author:  Ryan Allen [ Mon Mar 04, 2013 7:55 am ]
Dang, you sound like my wife, always giving me grief about my lounger! She's been wanting to throw that thing out since I brought it home.
The current hoses are just water hose lines cut to length. I plan to order the appropriate pre-made hoses once I get the correct lengths. I am just concerned about how steep the fuel has to travel from the firewall to the fuel pump (the hose that I am holding in the picture).
Author:  dan [ Mon Mar 04, 2013 8:21 am ]
You going to run a backup pump arent you Ryan? It would appear that the only time that might give you a little trouble is if that pump gave up. I dont run a fuel pump so Rich and those that use them would know more about it than I.......Dan
Author:  Pacer 20 [ Mon Mar 04, 2013 10:36 am ]
I dont want to restart a discution but the design is a gravity feed system. So no fuel pump needed.
For my part I have the same fuel pump on my engine, a electric fuel pump too and when is the time I removed all this extra stuff.
If I dont need it, I dont want it!
My 2 cents!
Author:  Fraser MacPhee [ Mon Mar 04, 2013 10:49 am ]
If I had a fuel system that would benefit from, or necessitated a fuel pump, I would have it. So far, neither T-18 I have owned has had one, and neither has ever exhibited a characteristic that gave me pause to think of installing one.
I'm a good KISSer. (Tierry - means Keep It Simple Stupid)
Ryan - my lounger, having drawn the ire of my wife for several years, graces Homey's and my hangar better than Ethan Allen could ever hope.
Author:  Ryan Allen [ Mon Mar 04, 2013 1:09 pm ]
I do have an electric fuel pump on the firewall that feeds that uphill run of fuel line. I will be curious to see what my fuel rate tests come out to be with this setup. I hope it passes because the only other thing to do is raise the level of where the fuel line passes through the firewall.
Author:  Rich Brazell [ Mon Mar 04, 2013 5:42 pm ]
I have my fuel pressure sender on the oulet port of the mechanical pump . With the Facet pump on (engine off) I get about 4-6 psi on the gauge . No real difference with the engine running . I turn the Facet pump off after T/O (turn it back on for landing) and still get 5-6 psi from the engine pump . As a side note when I was having carb problems I disconnected the fuel line to the carb and with the fuel valve on (no boost pump on) I was getting an amazing amount of gravity flow thru the Facet pump and the engine driven pump (check valves) ! I think we have beat to death the gravity flow vs pump issue . I just like having
positive pressure" to the carb . BOOM !
I don't think you need to raise the fuel level . :P
Author:  Ryan Allen [ Mon Mar 04, 2013 8:14 pm ]
Thats where I plan to put my fuel pressure sensor so thats a good reference.
Author:  dan [ Mon Mar 04, 2013 10:53 pm ]
Bingo!!!! there you go Ryan, Thanks Rich, we have a wealth of info here and I just knew the answer would surface!! This is the premier spot for systems on a Thorp, if you need info on how to,or info on how not to, it's all right here and all one has to do is ask.......Dan
Author:  leewwalton [ Tue Mar 05, 2013 12:18 pm ]
In the end the carb is still below the bottom of the fuel tank. You have fuel pumps, don't worry about the routing/angle etc. If you've ever flown a low wing (fuel in wings ... RV for example) their pumps are working a lot harder than in a Thorp. Gravity is gravity, the fuel will end up at the lowest point regardless of routing. We are mostly concerned with routing in a pure gravity feed system to maintain the correct PSI to the carb, again as you have fuel pumps you do not need to be as concerned.
Author:  Ryan Allen [ Tue Mar 05, 2013 1:52 pm ]
You are right Dan, this is all good info for me. Seeing as how this is my first foray into the experimental thing, I greatly appreciate all you guys with the "know how" chiming in.
