Fuel Tank Removal
http://thorp18.com/thorpforum/viewtopic.php?f=19&t=7177
Page 3 of 3
Author:  chuck [ Sat Dec 22, 2012 8:59 pm ]
Post subject:  Re: Fuel Tank Removal
RB: This relic is not going back in, was really more interested in the history of this type of tank. I've already had some discussions with having one fabricated, unless I can find one out there in Thorp land not being utilized. The screen looked a bit bent but nothing plugging it up; fortunately! I think this leak was a blessing in disguise.
I just got off the phone with my ole pal Les Conwell and he had his fiberglass tank in for 22 years until the Sun n Fun incident 2 years ago, no problems. I think I'm still sticking with metal, just reviewing all my options.
Author:  Rich Brazell [ Sat Dec 22, 2012 10:12 pm ]
You had me worried ! I thought you were going to use your kilt repair kit on the thing ! ::)
Author:  dickwolff [ Sun Dec 23, 2012 3:54 pm ]
Whatever you do, Chuckles, DON'T put a Thermos cap back in. Be sure to install a positive locking cap like Bruce Finney did.
I put a threaded cap in mine, which I bought from Summit Racing, including bung and O-ring. In retrospect, I wish I had done it exactly like Bruce did because there's not a lot of room in there for a raised filler neck.
While you are at it, look around at scupper designs. I did mine like Bruce, but afterwards I saw one somewhere that spilled the fuel to the right side of the fuel door and into a fairly generous reservoir on the right SIDE of the tank, between the tank and the outboard skin, and then to a drain tube through the floor.
Author:  chuck [ Sat Jan 05, 2013 8:59 am ]
Hi I'm Chuck and will be your autopilot for today's flight.
Author:  fytrplt [ Sat Jan 05, 2013 9:14 pm ]
That's what I call getting into your work.
Author:  Victor J Thompson [ Sat Jan 05, 2013 10:00 pm ]
While you don't want to be in the fuel tank location every weekend,.... Chuck your picture of you leaning on your removalble dash panel, has sold me on modifying my floor to make it removeable ~ I like the ease of accessing the back of the dash, break reservoir, rudder contolls, etc.
Good find on the fuel tank leak.
Was this fuel tank in from original construction?
Author:  Rich Brazell [ Sat Jan 05, 2013 11:46 pm ]
Chuck: I think a Dingo ate your fuel tank ! Not sure if that's a smile that you're happy the tank is out or a smile that your have a butt load of work to do ? :o Anycase glad I am on the other side of my panel ! BOOM !
Author:  chuck [ Sun Jan 06, 2013 8:18 am ]
Victor-there
Author:  Rich Brazell [ Sun Jan 06, 2013 7:43 pm ]
Chuck : I am sure you labeled all the wires and made a wire key . If you need "tubes" for those old heavy avionics I probably have a few in the attic ! I remember going down to the Thrifty Drug
store and using their "tube tester" when our state of the art B & W TV went goofy ! ???
Author:  chuck [ Tue Mar 19, 2013 7:35 pm ]
My freshly fabricated tank arrived today and it looks awesome, very professionally constructed. And I'm happy to say it fits perfectly (yes I've already installed it) and the gas cap and sending unit line up with the cut outs in the fuselage. It was twice pressure tested, so, hopefully no surprises once fuel is introduced. Notice the welded reinforcements, particularly around the lower bung; the source of my previous tanks leak.
Sun n Fun is starting to look like a possibility again!
Author:  dan [ Tue Mar 19, 2013 10:08 pm ]
That's a good lookin tank Chuck, the welds look like they have a little muscle to em. I,welded an AN fitting to the bottom of my tank and reinforced it with .125 thk t-6. It is an AN pipe bushing,so i have a male thread protruding from the bottom of the tank.........Dan
Author:  Rich Brazell [ Wed Mar 20, 2013 5:27 pm ]
Nice "Hunk of Burning Love ! " :-* Looks like a nice job of welding with very little distortion of the metal . ;) The welds on my tank were no where as nice . The tank was pressure tested , but I tested it on arrival . To help me sleep at nite I applied Van's tank seal to all the exterior welds . ??? You did say you had an access cover for the sending unit just in case it needs to be R & R . ;)
Page 3 of 3 All times are UTC - 6 hours [ DST ]
