Cowl rods
http://thorp18.com/thorpforum/viewtopic.php?f=17&t=8615
Author:  Ptbob484 [ Wed Jun 02, 2021 4:43 pm ]
Post subject:  Cowl rods
Has anyone fabricated up a couple of rods to hold open the cowling halves when they are opened for inspection? If so, can you share how you did it?
Thanks!
Dean
Author:  Rich Brazell [ Wed Jun 02, 2021 7:26 pm ]
Post subject:  Re: Cowl rods
Copy%20(2)%20of%20S18%20hinged%20cowl%20cheeks%20001.jpg [ 1.32 MiB | Viewed 8772 times ]
I did what you are talking about . Some scrap alum. tubing . A couple of fittings to hold the gizmo in place . Assuming you have an enclosed pleminum all you need are the (3) fittings to hold the rod in the up and stowed position . A small pivot fitting which the alum. rod will rotate on . A spring type "squeeze" fitting to hold the rod in the up and stowed position and a small teat type fitting to place the end of the rod in to hold it in place . The hard part is the concealed hinge fittings that are attached to the upper part of the cowl and(2) pieces of hinge to attach the concealed hinge . I believe most of the parts are from McMaster-Carr . The hinges you will have to goggle for . It's been 10 years since I did this mod .
