| rear position light http://thorp18.com/thorpforum/viewtopic.php?f=16&t=6479 |
| Author: | lance38dt [ Wed Jan 12, 2011 3:41 pm ] |
| Post subject: | rear position light |
My rear position light has been in need of a little update, I found at superbrightlede.com some interesting items. I received today a led bulb, 115X-X3Xw a 4 watt LED with an 1156 base and an LSC-100B pulsing module, it pulses the LED 6 times a second in two 3 burst patterns. It`s very bright, looks to be about 100 lumens with a 9 volt source.The pulse unit is small and is under 1 OZ. Price to my door was $30.25, for both. Further info. after the install, a cheap upgrade. ![]() ![]() Lance38dt |
| Author: | lance38dt [ Sat Jan 15, 2011 5:15 pm ] |
Installed the LED and the pulsing unit today, easy, fast, and very effective. specs says 160 lumens, very bright, beats the price of a rear strobe by far. Lance |
| Author: | Rich Brazell [ Sat Jan 15, 2011 10:35 pm ] |
The price is right ! Now if it was called an Aviation led lite, the price would be 3x's. [}:)] RB |
| Author: | Hoov330 [ Mon Jan 17, 2011 6:52 pm ] |
I bought one of these also....sweet fit right in and is bright. The strobe unit was able to attach right inside the rudder with no problems. Now see what I can find for the tips |
| Author: | lance38dt [ Mon Jan 17, 2011 7:57 pm ] |
I thought of that also,all you would need is two sockets with a mount and you have a good serviceable strobe at a rock bottom price. You could double up on the LEDS and still be under the weight and way under price of a typical strobe unit. Lance |
| Author: | Bill Williams [ Tue Jan 18, 2011 5:26 am ] |
Look at UNDERBODY LIGHTS, they sell a strobe kit for 90 bucks. |
