It is currently Fri Oct 23, 2026 8:14 am
 Post subject: Re: Gremlins
PostPosted: Wed May 07, 2014 4:27 pm
A little "Butch Wax" would probably smooth things over and the bearing would appreciate it ! ???
PostPosted: Wed May 07, 2014 8:21 pm
Yep, when you burn
Out a pelenium beleviator you will get gas under the left wing and in will cause
The air in the tire on the drivers side to have corners.....
PostPosted: Wed May 07, 2014 9:56 pm
I must be part Vulcan as I understood everything you said ! :o Live long and fly often ! ???
PostPosted: Mon May 12, 2014 8:46 am
Yesterday I tested all the spark plugs - set the multimeter at 2000 ohms - they all tested out between 1050 and 1350 ohms. The loose wire at the mag turned out to be the ground wire from the P-lead shielding to the mag case screw (slick mag). it was hanging on by 2 strands to the P-lead shielding - Once determined and fixed, all comms back to normal. All in all a good exercise as I became more comfy with the charging, electrical and ignition system. Thanks for all the advice!
PostPosted: Mon May 12, 2014 4:01 pm
The "edit" button seems to have disappeared.....I should add to the above that Bruce had it right about the P-Leads....and the admittedly poor excuse I have for not having seen it sooner, is that it was the right mag and the P-lead and ground connx's are on the underside and difficult to see in the sea of udder stuff that exists in proximity.....and it was dark,......and I was tired.....and hungry,.....and thirsty for barley pop.......???.....REALLY thirsty!!
lance38dt
PostPosted: Tue May 13, 2014 12:30 pm
Now we con all check our P-leads,I for one will.
Lance 38dt
PostPosted: Tue May 13, 2014 9:53 pm
I'll just check my barley pop. Frase, I'll never admit to your bride, but I've had two to three S- bocks a day to soothe the nerves. Good for what ails ya. Besides, they are free here.
PostPosted: Tue May 13, 2014 11:08 pm
FREE ! ??? Sign me up ! ;) Remember my Motto...(Free is better than Cheap ! ) :P
[ Time : 0.334s | 10 Queries | GZIP : On ]
