| Smoke System http://thorp18.com/thorpforum/viewtopic.php?f=13&t=8709 |
| Author: | Ptbob484 [ Mon May 30, 2022 6:18 pm ] |
| Post subject: | Smoke System |
Hi ya'll! Has anyone installed a smoke system who may be willing to share the parts list ? Thanks so much!! |
| Author: | Hagle347 [ Sun Jun 05, 2022 10:26 am ] |
| Post subject: | Re: Smoke System |
David Read has a smoke system on his Thorp as well as Bernie Fried. Guys? |
| Author: | david read [ Sun Jun 05, 2022 8:20 pm ] |
I don’t really have a parts list. I use a fuel pump that a friend gave me. He once told me the E8845 available from Amazon should be similar. I pump through a check valve to prevent exhaust pressure from coming back into the tank when the pump is off. I ran a 3/8” OD aluminum tube to a T, then 1/4 flex hoses to a fitting on the exhaust pipe. I welded a stainless 1/4 coupler into the exhaust pipe and screwed a brass MIP to flare adapter into that. No nozzle, just dump it into the pipe. I have used transmission fluid, half tranny fluid and diesel, and pure diesel. I always end up with some residue in the belly. Now I am getting some smoke oil from a crop duster and the residue is much lighter. I would say it puts out around 3 quarts per minute |
| Author: | Doug S [ Mon Jun 06, 2022 6:48 pm ] |
Here is the pump I have used on several systems. Seems to work well. ![]()
