Ptbob484
 Post subject: Smoke System
PostPosted: Mon May 30, 2022 6:18 pm
Hi ya'll! Has anyone installed a smoke system who may be willing to share the parts list ?
Thanks so much!!
 Post subject: Re: Smoke System
PostPosted: Sun Jun 05, 2022 10:26 am
David Read has a smoke system on his Thorp as well as Bernie Fried. Guys?
PostPosted: Sun Jun 05, 2022 8:20 pm
I don’t really have a parts list. I use a fuel pump that a friend gave me. He once told me the E8845 available from Amazon should be similar. I pump through a check valve to prevent exhaust pressure from coming back into the tank when the pump is off. I ran a 3/8” OD aluminum tube to a T, then 1/4 flex hoses to a fitting on the exhaust pipe. I welded a stainless 1/4 coupler into the exhaust pipe and screwed a brass MIP to flare adapter into that. No nozzle, just dump it into the pipe. I have used transmission fluid, half tranny fluid and diesel, and pure diesel. I always end up with some residue in the belly. Now I am getting some smoke oil from a crop duster and the residue is much lighter. I would say it puts out around 3 quarts per minute
PostPosted: Mon Jun 06, 2022 6:48 pm
Here is the pump I have used on several systems. Seems to work well.
[ Time : 0.148s | 9 Queries | GZIP : On ]
