chadmaisel2
 Post subject: Tailbeacon
PostPosted: Mon Oct 28, 2019 5:45 pm
Anyone install one on their Thorp? I can't see how this thing will fit.
 Post subject: Re: Tailbeacon
PostPosted: Mon Oct 28, 2019 6:20 pm
This assumes you have an existing tail light: It appears the uavionix website says you screw the uavionix mount onto the existing tail light base, and put the tailbeacon into the mount and lock it into a down position. Here is a link to the manual, with installation instructions on page 21
https://uavionix.com/downloads/tailbeac ... -Rev-B.pdf
chadmaisel2
PostPosted: Mon Oct 28, 2019 6:22 pm
I've read the instructions but it looks like I need to drill out some rivets to get the actual light socket out so that the beacon fits in the hole and I can wire it up. Here is a pic.
PostPosted: Mon Oct 28, 2019 6:31 pm
I see what you mean. It sure looks like you're going to need to drill out a couple of rivets in order to mount the tailbeacon base.
PostPosted: Tue Oct 29, 2019 10:13 am
Yes usually that socket is not riveted in ... typically the upper and lower rivets on your plane are screws and the base is tapped. I'd drill those out and tap them for the skybeacon.
chadmaisel2
PostPosted: Tue Oct 29, 2019 2:40 pm
Thanks Lee, I'll give that a go.
Unclerap
PostPosted: Tue Oct 29, 2019 4:42 pm
Yes, that's how you do it. I've done 2: An RV7 and a Sundowner. The 7 required a bit of work to get the TB mount to fit, the Sundowner was R&R. From what I'm reading on another site, the Garmin transponders with digital encoders work first time. King Txps seem to be ok. The old Collins and Narcos tend to be problematic and require a call to uAvionix for tech support, which is very responsive.
Rap
Base: KALX
N8786
SN 929
chadmaisel2
PostPosted: Sun Dec 08, 2019 3:45 pm
Thought I'd post an update. Got it all going and past the faa test - guess this baby will still be flying next month :D
[ Time : 0.203s | 11 Queries | GZIP : On ]
