| King KT 76A to Stratus EGR ADS-B TRANSPONDER http://thorp18.com/thorpforum/viewtopic.php?f=13&t=8080 |
| Author: | 1albee [ Sun Apr 30, 2017 5:43 pm ] |
| Post subject: | King KT 76A to Stratus EGR ADS-B TRANSPONDER |
I have a King KT76A transponder, was able to get a deal on a Stratus EGR. This is the unit with a built in WASS GPS, got a great deal from Pacific Coast Avionics. With the FAA $500.00 rebate the unit will be just over $2,000.00, I am installing it myself (I have all the tools) I will post the results after install. If anyone needs a operating KT 76 A to get by for the interim for $250.00 I will have mine removed next week. Phil Albee 118BC |
| Author: | d.grimm [ Mon May 01, 2017 6:35 am ] |
| Post subject: | Re: King KT 76A to Stratus EGR ADS-B TRANSPONDER |
I am doing the same upgrade this week. Replacing a Narco 155. I'll pass along any gotchas, looks pretty straight forward. Dave |
| Author: | BobMoe [ Mon May 01, 2017 11:27 am ] |
How about a link. https://www.pacificcoastavionics.com/pr ... s-esg.aspx |
| Author: | Lou [ Mon May 01, 2017 1:24 pm ] |
Phil check your PM |
| Author: | 1albee [ Tue May 30, 2017 7:35 pm ] |
The Stratus EGR went in pretty easy, there are a bucket of grounds though, I installed a new ACK30 .9 at the same time to have a RS232 connection available if needed later. I did need to install a additional GPS antenna for the ADS-B WASS part of the setup. Put it on the turtle deck. I have powered up the units and set the parameter's, everything went smooth. All I need is to do the check flight. The used transponder package that came out has been sold. Thanks Phil |
| Author: | 1albee [ Tue Sep 19, 2017 4:25 am ] |
Was able to do the ADS-B proof of operation flight last weekend, flew for a little over one hour with the required turns, headings and altitude changes in the mode C veil. Went to the web site later and got a clean flight report (no items highlighted in red) later that day received a second report with the incentive number. Took all of this with the original reservation number to a third web site (all of the websites are on the AOPA site including instructions and links)and was able to input all required info, (it took about 5 min's) and got a green light on the rebate. About one day later I received a email that my rebate was approved and I should receive a check in 4 to 6 weeks. Phil 118 BC |
| Author: | James Grahn [ Tue Sep 19, 2017 6:47 pm ] |
Remind me to talk with you about that at KVIS Cubes |
| Author: | 1albee [ Tue Sep 19, 2017 9:41 pm ] |
Will do |
| Author: | 1albee [ Tue Sep 26, 2017 5:26 am ] |
Received $500.00 check yesterday from the FAA (think I am going to frame it ) It took just about a week from the time I submitted the final request on there website. I am happy with the process and now I don't have to use the Thorp as hanger art in 2020.Phil 118BC |
