| Stainless steel "TED" transponder antenna http://thorp18.com/thorpforum/viewtopic.php?f=13&t=7829 |
| Author: | Rich Brazell [ Mon Sep 07, 2015 5:05 pm ] |
| Post subject: | Stainless steel "TED" transponder antenna |
During my last 24 month x-pondr check it was noted that the stainless steel antenna had a bit of "corrosion"/crude on it that was interfering with the ground test . It would only "test" if the probe for the test box was rotated around the antenna to find a sweet spot . We cleaned it with a 3M pad and now checks good on deck ! Something you might want to consider before your next test is to clean the thing with a scotch brite pad . RB
| Author: | Ryan Allen [ Mon Sep 07, 2015 7:31 pm ] |
| Post subject: | Re: Stainless steel "TED" transponder antenna |
good tip. my xpnder check is tomorrow. |
