Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
Tim Brown
PostPosted: Tue Oct 09, 2012 3:58 pm
Thanks a million....
I just got back from Lyncrest where I checked the sensors....well sort of.... They all reported accurate temp in the hangar (42f)...It would be a bit of a task to remove them (and I tried) Biggest problem is that it appears to require a tool that I don't have; a thin walled 1/2" deep socket with a slot cut in the side to pass the wire from the sensor.
Instead I had a look at the airflow and despite the fact they have been there for 260 hrs, I removed the landing lights from the cowl intakes. I couldn't test fly due the Wx (snow and low ceilings) but hope that's the answer.
File comment: there is a matching light on the other side
PostPosted: Wed Oct 10, 2012 9:15 am
Tim - ya know, looking at your baffling, it appears there is nothing containing the air from escaping around the front area around the starter/ring gear - I wonder whether you are getting enough pressure in the upper cowl area to force the air from the top down through the cylinder fins and hence cooling the heads.
PostPosted: Wed Oct 10, 2012 9:16 am
PostPosted: Wed Oct 10, 2012 9:27 am
Look again senior' ... That style of baffling contains the air from below. The dam is the vertical piece that extends to the lower half of the cowl.
PostPosted: Wed Oct 10, 2012 9:40 am
Yeah, was looking at that.....but still curious as to the configuration and how the system pressurizes vs what I am used to seeing - Tim has a much higher volume of air in his containment/pressure area and more potential for leakage hence reducing the pressure - For all I know, it may be a better config than what I have.......having said that, my engine runs too cool with the new baffling - last night I put duct tape over my oil cooler, as the daytime highs are now getting close to a cool 70 deg F.....that's 20 deg C and still thong weather for you loons...:).
Tim Brown
PostPosted: Wed Oct 10, 2012 10:09 am
This is what it looks like w/o the cowl
PostPosted: Wed Oct 10, 2012 10:24 am
Tim
PostPosted: Wed Oct 10, 2012 1:07 pm
Tim's setup is pretty standard .. N51863 had that style when we had the 0-320. We went to the "ramp" style for drag reduction. If you look at most spam cans they have the same style as Tim and several others. I believe John evens baffles are set up like this too.
PostPosted: Wed Oct 10, 2012 2:04 pm
Are inter-cyclinder baffles present?
Tim Brown
PostPosted: Thu Oct 11, 2012 4:27 pm
Port side...
Tim Brown
PostPosted: Thu Oct 11, 2012 4:29 pm
Starboard side
Tim Brown
PostPosted: Thu Oct 11, 2012 4:33 pm
Looks like the inter-cylinder baffles are present
PostPosted: Thu Oct 11, 2012 6:06 pm
What is that baffling material ? Looks like something off of Fozzie Bear ! :o
Tim Brown
PostPosted: Thu Oct 11, 2012 6:27 pm
Its a heavy felt....fozzie bear indeed :)
PostPosted: Thu Oct 11, 2012 8:28 pm
That is a piss poor baffle system. Without baffles blocking the cylinders and a dam around the flywheel the air is staying stagnet around the engine and not going up and over and through the cylinders.
[ Time : 0.327s | 11 Queries | GZIP : On ]
