| Drilling 215 inner wing and 315 outer spar fittings for pins http://thorp18.com/thorpforum/viewtopic.php?f=10&t=8817 |
| Author: | James Grahn [ Fri Mar 01, 2024 12:39 am ] |
| Post subject: | Re: Drilling 215 inner wing and 315 outer spar fittings for |
That should work. Be advised that there is slop in how the brackets mount to the spar caps. So if those have been drilled, you need to tak that into account. Cubes |
| Author: | Rv3maker [ Fri Mar 01, 2024 10:24 am ] |
Hey Cubes, I thought about that realizing that the dimensions/tightness of the two 215 pieces do change slightly as you install/torque down the AN4 bolts. My inner spar 215 cap holes have been drilled. So, I am thinking as long as I put in 2-4 AN4 bolts top and bottom to hold the 215's in place on the caps I could drill/ream the locking pin holes to size and then when doing the final install of the 215's on to the inner spar I could do it with the pins securely installed in the holes and the 315's temp installed. I believe this should keep alignment for the final install of all the AN4 bolts in the 215's. Agree? Alternative would be to install every mount bolt on the 215's permanently and then drill/ream the pin holes to final dimensions. I was going to delay the final install the 215's to be able to get a bucking bar on the top and bottom spar caps rivets for the skins. Then slide the 215's/spacers in place (supposed to be installed "wet") and complete the install and final torque of the AN4's (I may have a few AN174's in lieu of AN4's). This is where I would install the pins in then 215/315 to keep that tight alignment. Does this make sense? Rob |
| Author: | fytrplt [ Fri Mar 01, 2024 7:49 pm ] |
I built a seven degree jig to clamp the two top spars. Then built everything around that. |
| Author: | James Grahn [ Fri Mar 01, 2024 8:50 pm ] |
That will work. But you also need to think about the sweep of the wing. I have seen wings built that do not match inner to outer because the spar cap bolts were not taken into account. In other words, you not only have dihedral to think about, but also do the leading edges of the inner and outer line up and is there any unintended wing sweep. Do that by eliminating as many variables as possible. Measure the distance from the inner wing fittings to the leading edge. Then compare that with the outer. Are the aft spars drilled? If not, you can account for sweep back there. You can also account for any unintended twist there as well. Lee Walton came up with a beautiful cam setup to adjust twist via the trailing edge attachment fitting. Cubes |
| Author: | James Grahn [ Mon Jun 10, 2024 1:26 pm ] |
Well done. I know drilling very expensive parts is something you do not want to do again. Cubes |
| Author: | James Grahn [ Tue Jun 11, 2024 11:17 am ] |
You are not going to hurt a pin with a brass hammer. All good. Cubes |
| Author: | Rich Brazell [ Tue Jun 11, 2024 1:56 pm ] |
I use a small Craftsman soft faced mallet , hard rubber on one end and hard plastic on the other end to install my pins . Not a problem in 13 years and ZERO play in the wing . I use the plans made extractor to remove the pins . Works "Most Excellent !" One last note , I marked my pins with a "T" for top and a "B" for bottom . Probably not necessary , but it makes me feel Muey Bueno ! RB NX115RX 2019 |
