| Centre wing spar cap http://thorp18.com/thorpforum/viewtopic.php?f=10&t=8503 |
| Author: | rrobut [ Wed Jul 15, 2020 5:36 am ] |
| Post subject: | Centre wing spar cap |
On the S 18, Drawing number 227 states that 1 cap 2x2x0.25 2014 T6 channel is required. The drawing seems to show that it is 1.25x2x1.35x0.25. Alcoa Die 892 I am a little confused as to the actual size that is to be ordered. |
| Author: | James Grahn [ Wed Jul 15, 2020 1:04 pm ] |
| Post subject: | Re: Centre wing spar cap |
It is a machined piece. That’s why you see different dimensions. Cubes |
| Author: | rrobut [ Fri Jul 17, 2020 6:45 am ] |
Thanks Cubes for the prompt reply. So it starts as a 2x2x2x.25 channel and both legs are machined to about 1.25. The outer one at the fitting end tapered. Both machined full length to the reduced dimension Rob |
