| Folding wing photos http://thorp18.com/thorpforum/viewtopic.php?f=10&t=7724 |
| Author: | ljkrume [ Tue Feb 24, 2015 1:27 am ] |
| Post subject: | Folding wing photos |
Just posted a few photos of the folding wing joint in my album. Haven't seen too many other close-ups on this site. Hope it helps. Les, in Albuquerque |
| Author: | jrevens [ Tue Feb 24, 2015 11:33 am ] |
| Post subject: | Re: Folding wing photos |
That looks really good Les... nice work! |
| Author: | Ryan Allen [ Tue Feb 24, 2015 1:01 pm ] |
that all looks really good. The parts all look very professional! Out of curiosity, did you fabricate (what looks like to me) that u-joint type connection near the rear spar? That would seem difficult to precisely fabricate. |
| Author: | ljkrume [ Wed Feb 25, 2015 1:48 pm ] |
Don't know if you know, but the U-joint tube slides in and out to accomodate closing the gap between outer and center wing before installing the pin at the rear spar. The tube is hollow, but I pressed a solid plug in one end to machine the slot. The other part of the U-joint is milled with a slot also. Not too difficult. The U-joint does need to allow enough freedom on the wing to line up holes for the pin. Until you get it all worked out it takes a lot of on and off cycles with the wing. Good to have a helper for that. Les. |
