Pictures available here - Terry's Flickr Photostream
Thorp 29 Gallon Main tank $300 (Sold)
634L - Boot Cowl (Sold)
556-1 (2) - Control Mount Bracket
538L-3 - Rear Beam Inner Wing Fitting
498 - Bell crank arm
538L-3 (2) - Rear Beam Inner wing fitting
542L-4 (2) - Main Beam outer wing fitting
577 - Rudder Lower Hinge
553 - Plate - Aileron Control Horn (Sold)
565-2 - Beam Assembly fin doubler
637 (8) - Flap Hinge
510-1 - Mast Assem. Horiz Tail Bracket
491-2 - Brake Pedal Mast
492-1 - Pedal Support Bracket
579 - Mast Rudder (sold)
980
578 - Rudder Stop
719 - Terminal End Flex Shaft
513L (2) - Horiz Tail Arm Tube
521-1 (2) - Horix tail link tab linkage
722 - Bearing Trim Wheel
519-1 - Elev Control Sys Forward stop
519-2 - Elev Control Sys rear stop
495-2 - Horiz Push Pull Tube Fitting
567 - Rib Assem Bottom Rudder
A586 - Rib Third Rudder
517-5 - Horiz Tail Rib
478 - Conical Mount Ring
Complete Horizontal Stab
Pictures available here -Terry's Flickr Photostream
Contact :
This email address is being protected from spambots. You need JavaScript enabled to view it.
